prashobh Posted July 12, 2012 Share Posted July 12, 2012 Studio/Institution: studentGenre: Residential InteriorSoftware: 3DS Max 9,Vray 1.5sp2, PhotoshopDescription: Hi, I this is a learning project. I was trying to understand about lighting.I need your comments to understand mistakes, because I'm a beginner... Thanks.. Link to comment Share on other sites More sharing options...
mohammadebrahimian Posted July 12, 2012 Share Posted July 12, 2012 wow! it's good, I think you are not a beginner. Link to comment Share on other sites More sharing options...
Ismael Posted July 12, 2012 Share Posted July 12, 2012 The floor material needs more subdivisions to eliminate the grainy look sp under the bed. The plant 'clones' are too dull and plastic. Texture them and add more leaves/scale up or down to add variety. The reflections in the mirror; are them as you would see in a home? Most mirrors are made whit a greenish glass and a polished metal reflective bcking. The net effect is that objects seen reflected on them are slightly darker in the reflection. The plant at the end of the bed is just in the way, perhaps remove it. Otherwise, good clean render Link to comment Share on other sites More sharing options...
prashobh Posted July 13, 2012 Author Share Posted July 13, 2012 thank you Ebrahimian Link to comment Share on other sites More sharing options...
prashobh Posted July 13, 2012 Author Share Posted July 13, 2012 Thank you Ismael. Link to comment Share on other sites More sharing options...
Janwalli Posted July 16, 2012 Share Posted July 16, 2012 most comments have been made already - I would add this: check the hover bed ;-) It looks like the bed is hovering over the ground (foot end) Link to comment Share on other sites More sharing options...
sergiocaparelli Posted July 16, 2012 Share Posted July 16, 2012 i would change the floor texture or shader, there´s something weird with the reflections i think. And the flower pots on the nightstands look too plastic, just replacing them with some nice model would improve the scene. the rest of it looks really nice, i like the cloth material on the bed and the lighting! Link to comment Share on other sites More sharing options...
heni30 Posted August 12, 2012 Share Posted August 12, 2012 Hey, The things that stand out, besides what's been said are: Mattress looks to rectangular - the edges should be more rounded If those are square holes in the bed frame, you would see dark tone beyond The walls seem too bright at the top - like the ceil is open to the sun. The painting seems too busy visually and calls too much attention to itself It seems like one or both of the items on the night stands would be a lamp that you would use for reading and to switch off the light Link to comment Share on other sites More sharing options...
