reneweicker Posted August 15, 2012 Share Posted August 15, 2012 hello, I´m trying to use a dosch hdri for IBL, but however the sky appears gray not blue!? I use a spherical map in background channel, also in the other channels exept of illumination. So where´s the mistake? Isn´t it that simple? Could someone help me? thx Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted August 15, 2012 Share Posted August 15, 2012 Are you setting a higher multiplier than 1.0 on your VrayHDRI Map? Link to comment Share on other sites More sharing options...
reneweicker Posted August 15, 2012 Author Share Posted August 15, 2012 I made some quick renders with intensitiy on 1, 10 and 50 (backround channel)...it´s getting lighter & better but not as blue as shown in the dosch preview. please take a look at the attachments. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted August 15, 2012 Share Posted August 15, 2012 hmm... What's your camera like? Do you have vignette on? Try a very straight forward setting of: F = 11 or 16, ISO = 100, Shutter Speed = 100. Vignette, off, exposure on (obviously), and set the white balance to neutral. Also, try placing the map (start back at 1.0) into a vray dome light instead of the environment/background menu. As long as the dome lights had "invisible" un-ticked, you should be able to see it. You can also drop a jpeg of the image (set to spherical) into the Environment overrides for GI and Ref. People also supplement the direct lighting with a sun on reduced intensity, but you should be able to get this working without that. Link to comment Share on other sites More sharing options...
reneweicker Posted August 15, 2012 Author Share Posted August 15, 2012 I set the camera setting like you said. Intensitylevel 10 in background channel, cause I don´t know how to map the dome sky (it´s maxwell not vray...) it doesn´t seem to have a map channel...or I don´t know how to manage it. This guy had the same problem .. http://forums.cgarchitect.com/26601-hdri-skies-vray-sky-rendered-greyish.html .. but with vray. So, is there a similar button/checkbox in maxwell? Link to comment Share on other sites More sharing options...
matthewspencer Posted August 15, 2012 Share Posted August 15, 2012 I am thinking this almost certainly has to do with gamma settings. What software are you using? Adjust your gamma in Maxwell, and/or adjust your bitmap gamma settings if you're using some other host software like 3DS Max. EDIT: To be clear, is this Maxwell or Vray? Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted August 15, 2012 Share Posted August 15, 2012 EDIT: To be clear, is this Maxwell or Vray? This is my fault. I use the "Today's Post" category instead of searching specific forums. I'm sorry to cause confusion. I need to be better about checking the topics before I jump in like I know what's going on. The category is Maxwell. I brought up the VRay business. Link to comment Share on other sites More sharing options...
matthewspencer Posted August 15, 2012 Share Posted August 15, 2012 No worries Corey, I can understand how you're subconsciously longing to be involved with a superior rendering engine... XD Link to comment Share on other sites More sharing options...
reneweicker Posted August 16, 2012 Author Share Posted August 16, 2012 @ Matthew, you are right. I decrease the gamma value in Maxwell to 1.1 and everything is fine. blue sky. Thanks a lot! Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted August 16, 2012 Share Posted August 16, 2012 No worries Corey, I can understand how you're subconsciously longing to be involved with a superior rendering engine... XD hah. Touche Link to comment Share on other sites More sharing options...
