brennseldon Posted October 5, 2012 Share Posted October 5, 2012 Hi everyone, I've found posts that describe a similar problem, but nothing exactly fits the bill. This is my first post here, and I'm happy to be on board. This truly seems to be the hotspot for problem resolution so heregoes... I've lit my scene predominantly with vray plane lights but upon render, a faint ghost of the light plane is visible no matter what I do to the light check boxes. Has anyone experienced this? Any solutions? Thanks SO much, Brenn Link to comment Share on other sites More sharing options...
abhaysingh Posted October 5, 2012 Share Posted October 5, 2012 (edited) hi Brenn, can you post a quick render? ? he he iam about to sleep.... (using my phone). Edited October 5, 2012 by abhaysingh Link to comment Share on other sites More sharing options...
abhaysingh Posted October 5, 2012 Share Posted October 5, 2012 (edited) oh sorry got it..using phone so couldn' see. thats weird...what happens if you switch off those vray light planes?? can you post a max file with only your lights & bg?? we can test it. Edited October 5, 2012 by abhaysingh Link to comment Share on other sites More sharing options...
brennseldon Posted October 9, 2012 Author Share Posted October 9, 2012 I hope this will do. Thank you! https://dl.dropbox.com/u/55102675/vray-light.max If I switch off the light planes, the problem disappears, so it's obvious that it has to do with the light emission itself. Link to comment Share on other sites More sharing options...
abhaysingh Posted October 9, 2012 Share Posted October 9, 2012 Hi Brenn, I've tested your file.The problem is "Volume Fog" used by you in Atmosphere effects(press 8 to see).As far as i know "volume fog" is incompatible with Vray lights but never seen this ghost effect before.Instead you can use "Vray environment Fog". So just remove the effect "volume fog" from atmosphere dialog and use vray fog. Abhay. Link to comment Share on other sites More sharing options...
brennseldon Posted October 9, 2012 Author Share Posted October 9, 2012 Genius! Thank you! I was wracking my brain. It seems so obvious now. Lol. Thank you again! Link to comment Share on other sites More sharing options...
abhaysingh Posted October 9, 2012 Share Posted October 9, 2012 He He...Have a great day! Link to comment Share on other sites More sharing options...
