stayinwonderland Posted January 12, 2013 Share Posted January 12, 2013 Here's my render: You'll notice the splotches around the door frames. Settings are the typical render settings, set to quite high. IRR set to medium. LC set to about 1500/2000, noise to 0.005, shadow subdivs around 24, actually set Hsph to 100 to see if that would make a difference. Might not be a render issue, might be something to do with the geometry? Anyways, suggestion welcome! Link to comment Share on other sites More sharing options...
Jason Matthews Posted January 15, 2013 Share Posted January 15, 2013 First and foremost, check your geometry and make sure all is good. IMO this looks like GI settings gone wrong. First, change the IR Map back to default interp. samples (20) and Hsph (50) and turn off the LC. Try increasing the Interp samples. This will smooth out the solution. Then turn on default LC settings and tweak from there. Link to comment Share on other sites More sharing options...
heni30 Posted January 15, 2013 Share Posted January 15, 2013 I sometimes get this because of color bleeding. Try changing the material to say a light green with a vray override material for bleed correction and see if the splotches are still there. Link to comment Share on other sites More sharing options...
stayinwonderland Posted January 15, 2013 Author Share Posted January 15, 2013 Hi guys, thanks for the suggestions. I'll try those out and get back to you. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted January 15, 2013 Share Posted January 15, 2013 increasing interpolation will "erase" those light circles but you'll lose detail or precision in your GI mostly on small corners, some controls that most people overlook are more important, on Irradiance map you have Color Threshold, Normal Threshold and Distance Threshold, if you fix those before you keep increasing the over all values you'll get better results. Those light bounces can be because the glossies of those doors frames materials. also check there is not gap between your wall and the frames. Link to comment Share on other sites More sharing options...
stayinwonderland Posted January 16, 2013 Author Share Posted January 16, 2013 This is tricky. I'm afraid, as time is pressing, I'm having to chicken out of this one and just put curtains there. Increasing interp. samples up to 50 doesn't get rid of them and is a little less accurate/sharp. Tweaking the geometry shows some changes (gaps where the sun is coming through) but then it also shows up in places where the sun isn't coming through. Tweaking the clr threshold seems a little unintuitive. Each tweak costs me minutes before I see a result and I need to get this done. I suspect it's partly due to the gaps between geometry and partly due to something else that might require a full day of click - render - click - render. Thanks for the input though! Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted January 16, 2013 Share Posted January 16, 2013 Well that's why Arch viz is part Art and not only Science, the formula does not apply to every occasion. You can apply a flat color to the whole mesh, and do render region in the problematic areas, I think Distance threshold can help you here more than color Threshold, your moldings are rather small and curves create those strange light bounces. you can activate show samples to check if those are concentrating in the right areas. anyways put curtain is a valid option too Link to comment Share on other sites More sharing options...
Ismael Posted January 16, 2013 Share Posted January 16, 2013 Similar leaks addressed here, http://www.spot3d.com/vray/help/200R1/examples_lightcache.htm Link to comment Share on other sites More sharing options...
Chris MacDonald Posted January 16, 2013 Share Posted January 16, 2013 (edited) Don't increase the interpolation, You'll lose small details in the GI. Instead what you should do is turn on "detail enhancement" on your irradiance map, it'll increase the detail of your irradiance map around sharp corners & recesses - this almost always gets rid of light leaks for me, even on really low irradiance map settings. You'll also notice an improvement in your GI in other areas because of this too. Also, you could turn on "check sample visibility", which often helps. You have to remember that when VRay interpolates between samples it uses a radius function to decide which ones to interpolate between; this means that if the radius happens to grab a couple of samples from outside, they'll brighten the average of that point thus causing a "light leak". By turning on "check sample visibility" VRay evaluates whether or not there is any geometry dividing the samples that could affect the brightness of them when they're interpolated between. Edited January 16, 2013 by Macker Link to comment Share on other sites More sharing options...
stayinwonderland Posted January 16, 2013 Author Share Posted January 16, 2013 (edited) Client doesn't want curtains... Okaaay, so here's the latest render (just region-rendered the middle portion where the doors are): **view full image** Settings: Camera: f-number 4.0, shutter 80 DMC: 4/12 Reinhard: - burn 0.03 (need to let as much light in as poss without blowing out) IRR: medium 50/20, detail enhancement on (r = 60.0, subdivs = 0.3), check sample vis enabled LC: 1500 A/O: 0.6, 0.25m, subdivs 32 Noise: 0.005 I cleaned up the geometry and the detail enhancement helped but still getting leaks. Ideas? Thanks for all the help thus far! EDIT: I just increased the sun's photon emit radius from being very small to being as large as the house... that made things much worse. Edited January 16, 2013 by stayinwonderland Link to comment Share on other sites More sharing options...
Chris MacDonald Posted January 17, 2013 Share Posted January 17, 2013 The photon emit radius has nothing to do with your issue because you aren't using photon mapping in your scene . Try increasing the max rate on the irr map to -1, or even 0. Link to comment Share on other sites More sharing options...
heni30 Posted January 17, 2013 Share Posted January 17, 2013 As a down and dirty quick fix I would render the doors separately with plane lights and paste them in PS. They shouldn't look that different especially because you can tweak them separately. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted January 17, 2013 Share Posted January 17, 2013 IRR 50/20 seems a little low to me, it should be higher, now I don't see much GI problems in other part of the room, so, you may need to review that frame mesh, check if there is not flip polygons, the smooth groups are fine, if so try applying a flat material to it, and see how behave, maybe the glossiness of those moldings or something, Try using brute force in the second bounce, if it render fine then adjust your set up in Light cache Link to comment Share on other sites More sharing options...
Bruce Hart Posted January 17, 2013 Share Posted January 17, 2013 If you have "store direct light" on the Light Cache try turning it off. I'd bet a dollar this is the culprit Link to comment Share on other sites More sharing options...
stayinwonderland Posted January 17, 2013 Author Share Posted January 17, 2013 Ok, the story so far. These renders are 900px but are of the highest settings pretty much: Notes: IRR set to high, had to lower the overall exposure as I don't think that was helping (we're talking really low f-stop and burn set to 0.03 which might have been why some of the splotches were so bright). Detail enhancement is on. Still getting some issues though. Notes: This is the exact same render but I selected a region where the main issues exist and rendered with 'store direct light' unchecked and this has made some fairly noticeable difference. My next step is to try rendering a region of a 3000px image and see if that helps. What is kinda weird is that if I change something and that makes it worse, but then I change that one setting back to where it was, it doesn't then return to its previous state, it seems to have an organic nature to it. Also, I rendered a close-up of those areas and they're fine when not at a distance. The material, by the way, is very standard - no glossy effects. Link to comment Share on other sites More sharing options...
matthewgriswold Posted January 17, 2013 Share Posted January 17, 2013 (edited) Seems like we're all throwing in our 2cents, so mine is the Retrace Threshold. Check out example #4 - looks exactly like the problem you're experiencing. Seems to be an issue with the bright exterior + dark interior light cache samples intermixing, throwing off the IMap calculation. Hope this helps. Edited January 17, 2013 by matthewgriswold bright/dark mix-up Link to comment Share on other sites More sharing options...
stayinwonderland Posted January 17, 2013 Author Share Posted January 17, 2013 We have a winner! Matt wins the prize! The above was rendered with retrace enabled (default 1.0) and... note... detail enhancement turned off and IRR set to medium. Can't thank you enough, I would NEVER have found that. Link to comment Share on other sites More sharing options...
matthewgriswold Posted January 17, 2013 Share Posted January 17, 2013 Glad I could help out. Best of luck. Link to comment Share on other sites More sharing options...
