stayinwonderland Posted March 11, 2013 Share Posted March 11, 2013 I know this is probably futile to enquire, and it's not the first time I've mentioned it but... Does anyone else get this: They work using vray RT on a scene and then it just dies and will NEVER work for that scene again - ever. Start a new scene, no problem. But as far as RT is concerned, it's out to lunch until you start a new scene. This happens 100% of the time and it KILLS my production time. Link to comment Share on other sites More sharing options...
stayinwonderland Posted March 11, 2013 Author Share Posted March 11, 2013 That said... I just did an experiment where I chose a different viewport for the RT, that worked. I then went back to the original viewport and it worked there once again. So is this a graphics card issue... or...? Link to comment Share on other sites More sharing options...
Scott Schroeder Posted March 12, 2013 Share Posted March 12, 2013 I think it's an issue with Max and the active shade with RT in the background and it doesn't actually close. I ran into it before and found a solution, but damn if I can find that webpage. I'll do some Sherlock Holmesing and see if I can pull it up. Link to comment Share on other sites More sharing options...
Ismael Posted March 12, 2013 Share Posted March 12, 2013 http://www.spot3d.com/vray/help/rt100/render_3dsmax.htm Under 'Locks'? Maybe that's it. I'm doing a Sherlock too as I don't even own V-ray 2. Link to comment Share on other sites More sharing options...
