GTX Titan different models
Between the cheapest one (06G-P4-2790-KR) and the most expensive (06G-P4-2795-KR hydro copper signature).
There is 200$ difference and difference in:
-GPU Speed
-Texture Fill Rate
I mean, is there really a difference in performance with the same card?
Hydro Copper is EVGA's line that comes with a water-block, ready to be added to a custom water cooling loop (ho, your H100, or equivalent AIO WC / or "closed loop" won't work).
It is of course pre-overclocked by EVGA, and yes, it is faster than the "regular" Titan.
Titan cards are great overclockers even with the stock cooler, so you can match the factory OC EVGA has easily if you want. Ofc water allows you to go much higher.
The signature version in all cards, comes with certain "collectibles"...T-Shirts etc, to wear and brag around.
No additional performance gains - outside the very important e-peen that is.
