interiordesignchu Posted May 5, 2013 Share Posted May 5, 2013 i tried many settings, but couldn't figure out how to improve that jagged lines to clean sharp lines? please help, i am lil bit upset now...frustrated. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted May 9, 2013 Share Posted May 9, 2013 Higher antialiasing settings. Link to comment Share on other sites More sharing options...
M V Posted May 13, 2013 Share Posted May 13, 2013 Try Area AA filter. Also, you might want to look at your Adaptive DMC settings. What are you using for your Clr Threshold? .002-.004 for finals is a good setting. Link to comment Share on other sites More sharing options...
RayOfLight Posted May 15, 2013 Share Posted May 15, 2013 or even way faster: Use Adaptive Subdivision as Image Sampler, min rate at -1, max rate at 2, so DON'T use higher settings, that will work but it will also slow you down. Make sure Object Outline is checked, color treshold could be at 0.1, maybe lower, but you might not need it with object outline on. As filter I always have Area at 1.5. Works like a charm. Link to comment Share on other sites More sharing options...
interiordesignchu Posted October 27, 2013 Author Share Posted October 27, 2013 thanks! Link to comment Share on other sites More sharing options...
lasrador Posted December 3, 2013 Share Posted December 3, 2013 Even i was wondering the same thing.. the edges specially when the colour is white, tend to be blured. Its worse when they flow into a darker colour. Will give this a shot.. thnks a ton in advance Link to comment Share on other sites More sharing options...
mikejokes Posted March 3, 2014 Share Posted March 3, 2014 I have same question, sharp edges but not aliased. I noticed using area works great but the render does not look realistic. when edges are sharpened it really enhances the realism of the render but this leads to aliased edges. this is the render setting file i'm currently using, scene is a architectural model rendered with an alpha background and matte floor to catch transparent shadows. https://mega.co.nz/#!bcNCiarJ!PctlUNgCFOQpIe7a_MQa9rFylp3s8KcXkBRnRl7ow3E Any advice or tips would be greatly appreciated! Link to comment Share on other sites More sharing options...
raytracer2 Posted April 30, 2014 Share Posted April 30, 2014 Do you have Ambient Occlusion turned on? that helps to define details Link to comment Share on other sites More sharing options...
