nathanielshields Posted August 27, 2013 Share Posted August 27, 2013 I have been following this grass tutorial using the hair and fur modifier and ran into a problem. I have a number of trees in my scene that are just planes that I have applied a material on to (a bitmap of a tree with an opacity map). when I render, the grass does not show up behind the plane despite the fact that it should be mostly transparent around the tree. I have tried unticking the planes "visible to camera" tickbox in its object properties as well and when rendered it still renders the grass exactly the same. If I change its material to matte/shadow then I lose the tree image and therefore the shadow as well. I am thoroughly confused… is this something to do with the scanline renderer? If anyone has any solutions that would be amazing, thanks I am using 3ds max 2014. Rendering the main image in mental ray and the grass separately in scan line. Link to comment Share on other sites More sharing options...
