Alpha Channel Import Problem
TomA
Hi
I'm struggling to get my alpha channels (16bit RGB tif files) into a 16bit RGB psd file.
I use control/left click to select the alpha then right click-duplicate channel and it is not giving me the option to copy into the psd.
Any ideas or other ways to import alphas?
Thanks in advance.
T
when you have the PSD as your current file go to Select - Load Selection - then choose the open .TIFF from the dropdown. If its not there then for some reason its incompatible. Usually its either the mode (bit-depth / CMYK etc) or its a different size that makes it unable to work.
Otherwise you can select your channel, make it a solid on a layer and drag/drop the layer to the new file. Then you flatten it and copy/paste to a channel.
