when render in vray 3dsmax no materials appear...
xeniamast
Shift+T will get you to your asset tracking and you can see if you are missing any maps. May just need to point the maps to the correct path. Also check if you don't accidentally have an override material on your scene....and yes check correct camera exposure as Scott suggested.
Dear Desmarais,
I pressed Shift+T. Both the merged 3dsmax file and all materials have a yellow triangle with a (!) and say "unknown status". What would be the correct camera exposure?
Thanks in advance...
by the way, all materials can be seen on my screen before render...And I've read that "If it have already been instaled, you have to in the control panel, add/remove programs and change the 3dsmax install to remove the vault plugin.", so I removed the Vault plugin and now there is not the "unknown status" there.Even though materials are missing again....ouffff...
Edited by xeniamast
0AALglnh8BAB4OfgQA0FH8yIsXL1683q9PfgQAgAz8CACggx8BAHTwIwCAzv8BLamADEtWkW8AAAAASUVORK5CYII=
“Override mtl - this option allows the user to override the scene materials when rendering. All objects will be rendered with the chosen material, if one is selected, or with their default wireframe materials if no material is specified.”
so the result up to now is that following your image Ismael I could have my background revealed with textures. Then the new merged file can have textures but I have to insert them again on each item...let you know with final drawings..until then a big thank you to all of you!!!!!
Do you know how can I have 3d grass? I cannot find any interesting video on the net...????
Edited by xeniamast
Yes I had to press the mtl override off in order to have my materials open!
About multiscatter...I am going to search it, I am pretty new to vray and some 3ds max parametres...soon I will show how my project proceeds thanks to your help and my patience to find out what you are talking about when you support me with your advice :)
Great.
Multiscatter will not currently work with the VRay 3.0 Beta just an FYI if you do look into it. We all had to start somewhere...your skills will always keep building
