renderingdesigner Posted December 12, 2013 Share Posted December 12, 2013 Hello, i'm opening a file on MAX 2013, the file contains vray materials, i want to clear all, remaining only the model!. so i've completely reset all materials, erased all lingths and switched the rendered to Default, and then saved the file. When i open again the file, it's asking again for the vray Dll's!!!. How can i get an completely clean archive (without import-export)? Thanks Link to comment Share on other sites More sharing options...
Tommy L Posted December 13, 2013 Share Posted December 13, 2013 Which dll's? Link to comment Share on other sites More sharing options...
RyderSK Posted December 13, 2013 Share Posted December 13, 2013 http://www.scriptspot.com/3ds-max/scripts/removemissingplugins Comments reveal it works for 2012, should work for 2013 probably as well..if not, there could be an update, or you can ask the author to recompile. It's strongly undervalued what scriptspot contains :- ) I found this with 2 second and google. Anyway, I still do it with import/export (but I see that you like to avoid it this time) Link to comment Share on other sites More sharing options...
