vikneshvijayakumar Posted February 7, 2014 Share Posted February 7, 2014 Recently I downloaded 3ds Max 2014 trial from autodesk. It worked without any problems for a week. It all started when I updated my Nvidia 630M with a WHQL certified graphics driver. When I opened Max after the driver update it closed with an application error which says that, an error has occurred and the application will now close. Now it opens after a Product Update. But the viewport is completely white. It crashes if I open a file. Tried changing the viewport renderer from Nitrous to direct 3d and open GL. If I do that 3ds Max doesn't even start and gives the same application error. But it works fine even with nitrous viewport if started in Integrated graphics. Someone please give me a solution for this vague error :( Core i5-3210M @ 2.5 GHz Windows 7 Ultimate 64bit sp1 4GB RAM 1GB Nvidia GT630M Link to comment Share on other sites More sharing options...
erkutacar Posted February 12, 2014 Share Posted February 12, 2014 did u try to crack the trail? or does it give any error in any other 3d application? Link to comment Share on other sites More sharing options...
vikneshvijayakumar Posted February 13, 2014 Author Share Posted February 13, 2014 did u try to crack the trail? or does it give any error in any other 3d application? No, I didn't... Its only after the graphic driver update... I don't have any other 3d app installed.. But photoshop works fine. Link to comment Share on other sites More sharing options...
erkutacar Posted February 13, 2014 Share Posted February 13, 2014 u should try with video games and see if u have any problems.. r u sure u have downloaded the correct drivers? if so download it again, the package might be corrupted and when u install, choose custom install and check "perform clean install" Link to comment Share on other sites More sharing options...
