onesee Posted February 19, 2014 Share Posted February 19, 2014 I have a test scene and playing around with vray plane. I can't seem to give it geometry in the material editor to create a infinite rough road to the edge of the horizon. I added a vraydisplacementmod and fiddle around with the settings but it does not show any displacement. I added the same parameter to a normal plane that shows it just fine, so my question is can Vrayplane inherit any geometry displacement? I could get it to show some deformation if I make it transparent and add in a noise map. Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted February 19, 2014 Share Posted February 19, 2014 Its a bit early in the morning for me, but here is my logic: The vray plane is supposed to be infinately big in all directions. When you add displacement in your scene, usually the render takes quite a while to calculate the new geometry. If you added a displacement on your vray plane, the render would basically take forever since it calculates the displacement on a plane that goes on forever. Also the vray plane does not have any segments. This could be the reason it does not work, but i dont know for sure. Link to comment Share on other sites More sharing options...
Ismael Posted February 19, 2014 Share Posted February 19, 2014 From the help file for Vray 1.5 on th Notes section: http://help.chaosgroup.com/vray/help/150SP1/displMod_params.htm "VRayDisplacementMod has no effect on VRayPlane objects, VRayProxy objects or VRayFur objects." From the help file for Vray 2.0 on th Notes section: http://help.chaosgroup.com/vray/help/200R1/displMod_params.htm " VRayDisplacementMod has no effect on VRayPlane objects, VRayProxy objects or VRayFur objects." Link to comment Share on other sites More sharing options...
onesee Posted February 20, 2014 Author Share Posted February 20, 2014 Thanks for confirming it Ismael. This is also true in material editor, a shame that vrayplane doesn't seem to take on any z depth property. Link to comment Share on other sites More sharing options...
