adeebothman Posted April 14, 2014 Share Posted April 14, 2014 Dear all, Please help, my 3ds max design 2014 material slots turns all black. I've been facing this for one month already name it the solution in the website i already try the most of it. i'm using 1GB NVIDIA QUADRO K600. This kind of the solution that i try 1. Change the render engine to vray at the assign renderer. 2. set the gamm to 2.2 at the Gamma/Lut tabs setting 3. change from max.mental ray to Max at the custom UI and defualts switcher 4. and yes i already try to reinstal vray plugin. Any idea? Link to comment Share on other sites More sharing options...
paneli Posted April 18, 2014 Share Posted April 18, 2014 adeebothman said: Dear all, Please help, my 3ds max design 2014 material slots turns all black. I've been facing this for one month already name it the solution in the website i already try the most of it. i'm using 1GB NVIDIA QUADRO K600. This kind of the solution that i try 1. Change the render engine to vray at the assign renderer. 2. set the gamm to 2.2 at the Gamma/Lut tabs setting 3. change from max.mental ray to Max at the custom UI and defualts switcher 4. and yes i already try to reinstal vray plugin. Any idea? 1. Seems like a driver issue to me. Use this tool to define the certified driver for you GPU. http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534 2. Try toggling between Nitrous DX10/DX9 and OpenGL. 3. IMO you shout get your hands on a decent mid-range Geforce and drop the Quadro ripoff. Link to comment Share on other sites More sharing options...
Morne Erasmus Posted April 28, 2014 Share Posted April 28, 2014 So what changed in the last month? Did you install or uninstall anything recently? Can you actually render? Black vray material slots could be due to a license issue Link to comment Share on other sites More sharing options...
