philvanderloo Posted April 24, 2014 Share Posted April 24, 2014 I've downloaded CGsource's multi-texture map, which is a .DLT file, and I'm trying to figure out how to get it to show in my material map browser. max 2014 64 bit windows 7 Thank You Link to comment Share on other sites More sharing options...
Scott Schroeder Posted April 24, 2014 Share Posted April 24, 2014 You need to install it to the proper folder, which would be Max/Plugins if my memory serves me correctly. Link to comment Share on other sites More sharing options...
Tommy L Posted April 24, 2014 Share Posted April 24, 2014 put it inside max/plugins then restart max. It should then show up as a map type in the material browser. Link to comment Share on other sites More sharing options...
philvanderloo Posted April 25, 2014 Author Share Posted April 25, 2014 Thank You. I'm half way there. I put it in the stdplugs folder and it shows up in the slate material editor, (maps). How do I enable maps in the compact material editor? Link to comment Share on other sites More sharing options...
Tommy L Posted April 25, 2014 Share Posted April 25, 2014 Click on any swatch and it should open the map browser Link to comment Share on other sites More sharing options...
Zdravko Barisic Posted April 25, 2014 Share Posted April 25, 2014 This is your next doubt, I suppose, so check it on time... http://forums.cgarchitect.com/75956-multitexture-problem.html Link to comment Share on other sites More sharing options...
