jonathanpatrick Posted June 6, 2014 Share Posted June 6, 2014 Hello.. i'm need to the site. I am looking for any pointers and advice on how to take this scene to the next level. Thanks iN Link to comment Share on other sites More sharing options...
philippelamoureux Posted June 7, 2014 Share Posted June 7, 2014 I'm not an expert but you should allow the sunlight to enter the room. It will give some life to your image! I think it looks a bit flat with the current lights. Adding ambient occlusion will add alot of realism too. Good luck Link to comment Share on other sites More sharing options...
ashleyclarke Posted June 8, 2014 Share Posted June 8, 2014 You have a nice clean render but as has been said, it's very flat. You've got a large window open to the outside but there is no light coming though it. In real life that would be the main and possibly sole light source in the room. Use a Vray sun or direct light and have it set up to shine through the window and see how you go from there. Link to comment Share on other sites More sharing options...
jonathanpatrick Posted June 8, 2014 Author Share Posted June 8, 2014 I will try the ambient occlusion, but can this be produced with vray? Link to comment Share on other sites More sharing options...
jonathanpatrick Posted June 8, 2014 Author Share Posted June 8, 2014 Thank you. I am new to lighting. I will try the vray sun. I do agree that would make a huge difference. Link to comment Share on other sites More sharing options...
Chris MacDonald Posted June 9, 2014 Share Posted June 9, 2014 Definitely have your "primary" light source as the window if it is a daytime shot - also you should definitely increase the exposure of the picture you've photoshopped outside, it's way too dark. Link to comment Share on other sites More sharing options...
notamondayfan Posted June 11, 2014 Share Posted June 11, 2014 1. Reference 2. Contrast 3. Balance Done Link to comment Share on other sites More sharing options...
RyderSK Posted June 11, 2014 Share Posted June 11, 2014 1. Reference Right on. This should be made into first commandment of archviz: Thou shalt worship the reference until your mind is trained to genius level to freestyle (never). Link to comment Share on other sites More sharing options...
Scott Schroeder Posted June 11, 2014 Share Posted June 11, 2014 Right on. This should be made into first commandment of archviz: Thou shalt worship the reference until your mind is trained to genius level to freestyle (never). Print this out, frame it, and hang it above your workstation to see each and everyday. Link to comment Share on other sites More sharing options...
Ismael Posted June 11, 2014 Share Posted June 11, 2014 "Thou shalt worship the reference until your mind is trained to genius level to freestyle (never)." How many times a day we get a blog from a first time poster asking for help in reaching realism for a piece they just concocted and that, not even imagined! So much easier if the question was based on a reference goal. Link to comment Share on other sites More sharing options...
erkutacar Posted June 20, 2014 Share Posted June 20, 2014 remove the blinds and open a window. add a curtain flowing with the wind. place plants inside white pebbles. put a self illuminating texture on the tv screen, maybe a music video frame. uve got a bar there, add a shelf on the wall and some bottles on it. turn off the chandalier and turn on the table lamp. remove the wall on the left next to the pillar and make it corridoor. it will give more depth to the scene. add dvd boxes on the shelf above the tv. and i think u should use a darker stone texture or maybe parquet. Link to comment Share on other sites More sharing options...
