gordonheywood Posted July 30, 2014 Share Posted July 30, 2014 this has been really annoying me when trying to light this simple room I cannot get the light to pass through my window, I've tried every type of light as well as mental ray the only time it seems to work is when I choose ray traced shadows but I don't want to use that as it produces very hard edges. Strange thing is it will show the light passing through in the viewport but when rendering it doesn't. Any help would be appreciated. Thank you Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted July 30, 2014 Share Posted July 30, 2014 Sounds like a material issue. Can you post a screen shot of your Glass Material Settings? Link to comment Share on other sites More sharing options...
gordonheywood Posted July 30, 2014 Author Share Posted July 30, 2014 ye sure here they are I didn't change anything on any of the settings its just the mental ray arch and design think glass I haven't modified it in anyway and when I did to try and solve the problem ive come up empty handed Link to comment Share on other sites More sharing options...
Jon Berntsen Posted July 30, 2014 Share Posted July 30, 2014 Do you windows have thickness? Link to comment Share on other sites More sharing options...
gordonheywood Posted July 30, 2014 Author Share Posted July 30, 2014 no not at all in fact it seems that light will not pass through any object that has transparency when rendering buy again shows up fine in the viewport so perhaps a render setting is the problem ? Link to comment Share on other sites More sharing options...
Jon Berntsen Posted July 31, 2014 Share Posted July 31, 2014 no not at all in fact it seems that light will not pass through any object that has transparency when rendering buy again shows up fine in the viewport so perhaps a render setting is the problem ? Ok, then I won't be of any help, since I don't know mental ray that good. Hopefully someone else can help you out! Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted August 5, 2014 Share Posted August 5, 2014 Its been a while since i used mental ray, but perhaps this is the solution?: "If you are using Final Gather with a transparent surface, you may need to increase the FG trace depth values in the Render Settings window." Link to comment Share on other sites More sharing options...
