vincentg87 Posted August 4, 2014 Share Posted August 4, 2014 Hi guys, just some background information. I am an architectural visualizer working in Singapore. I bought a workstation about a year ago and used it from time to time for work. (rendering, Photoshop, the usual stuff). I have recently decided to take a break from my full-time job and do some freelance work from home. However, I came across some issue with vray and 3ds max crashing while handling jobs that takes over an hour to render. I would like to not only solve this issue. But also to prepare myself from other future problems. So getting into my main point, I would like to seek advice from experienced user, for comments on my PC inventory, whether there are any incompatibilities between software and hardware. I am slightly knowledgeable in the IT department thanks to google, so I will try my best to list out or the information needed. OS: Windows 7 Pro 64bit Softwares used: Photoshop CS5, 3dsmax 2014 with vray 2.4 below are the list of my PC hardware: Intel i7 3770 3.4GHZ 8MB Asus P8Z77 WS Leadtek Quadro 2000 1GB DDR5 PCI-E Kingston Hyper-X 12800/1600 (8GBx2) Samsung 840 Pro Series 128GB INT SSD WD Caviar Blue 500GB 3.5" 16MB Sata 3 Antec High Current Gamer M 620W Coolermaster Centrion 6 Thank you for taking your time to read Link to comment Share on other sites More sharing options...
numerobis Posted August 4, 2014 Share Posted August 4, 2014 if it is crashing only on longer jobs and RAM is not the point... did you check the temps? Are you using the boxed cooler? Link to comment Share on other sites More sharing options...
vincentg87 Posted August 5, 2014 Author Share Posted August 5, 2014 if it is crashing only on longer jobs and RAM is not the point... did you check the temps? Are you using the boxed cooler? Hi, are your referring to the temperature of my motherboard? I just did a google search. Apparently there is a setting on my motherboard that overclocks my cpu by default. Will have a look at that after work. Link to comment Share on other sites More sharing options...
numerobis Posted August 5, 2014 Share Posted August 5, 2014 Primarily to the CPU temperature. You can check it with Coretemp http://www.alcpu.com/CoreTemp/ But if your system is auto-overclocked, i think this is a not so unimportant detail... some numbers would be useful! - but i would say set it back to normal and see if your problem is gone. Link to comment Share on other sites More sharing options...
vincentg87 Posted August 12, 2014 Author Share Posted August 12, 2014 Hi all, sorry for the delayed response. I've been away for a business trip. The good news is that I solved the crashing while rendering issue. I opened up my casing and noticed the Asus logo on the motherboard was flashing red while rendering. A quick google shows that apparently there are 3 standard settings in the motherboard bios that controls the cpu, and it has been set to high performance by default. I basically just changed the setting to normal, ( Asus logo turned to blue ), rendered a 7 hour scene, no crashes ! Thank you all for information ! Link to comment Share on other sites More sharing options...
hoangsteven Posted August 26, 2014 Share Posted August 26, 2014 That's very strong PC, my dream!!! Link to comment Share on other sites More sharing options...
