hoseinasadi Posted August 9, 2014 Share Posted August 9, 2014 I applied a UVW Map with cylindrical mapping checked. however i get stretching along the base,on the top and also the bottom of the object. how do i fix those stretching? Link to comment Share on other sites More sharing options...
hoseinasadi Posted August 9, 2014 Author Share Posted August 9, 2014 alright found a quick solution. i added unwrap modifier on top , selected the stretched out faces and then applied planar from projection tab. Link to comment Share on other sites More sharing options...
jasonstewart Posted August 9, 2014 Share Posted August 9, 2014 You forgot to check "Cap" next to "Cylindrical". That should do the trick. Link to comment Share on other sites More sharing options...
