animation fade in objects with back faces hidden
cloudbreak
Hi all - I've tried to search for this with no luck so apologies if I've missed the solution somewhere else.
I'm rendering a simple animation in vRay (no GI) with a building fading in from 0% visible to 100%. See attached (chapel_01.jpg) for how it looks mid animation. What I really need though is slightly tricky to explain. I need to not see the hidden geometry when it's fading in. I'm just changing the object's visibility in object properties at keyframes so at the moment it's 'ghosting' in whereas I need to not be able to see geometry behind. I've mocked up what I need in photoshop (chapel_02.jpg) and if the camera was static then I'd just compile in post but the camera has movement so I can't. Any ideas?
Any help very gratefully received. Thanks. Jonty.
Edited by cloudbreak
Ah I see what you mean Nicolai - however I've got more buildings which I'm fading in and out and I'm not sure I've got time to remodel. Also even with interior faces deleted, you'd still see for example the back wall through the front one. I'm trying to avoid that, like in photoshop when you have a final rendered imaged and bring the trasparency from 0 to 100, you don't see through the object to rear walls etc, you just see a transparent version of the fully opaque render. See what I mean?
I think what I'll have to do, although I was trying to avoid it, is render the animation twice, once with the building hidden and again with the building fully visible and go from one to the other in Premiere. Bit of a pain as it means twice the render time so if anyone's got any other alternatives I'd love to hear them.
Cheers.
Just render out one frame without the building and one frame with the building ONLY. That way that second building only pass will fly as far as render times. If you need shadows, just set up the proper matte objects. There is no need to fully render 2 frames of each pass.
Doing this in post is the best way to do it. I don't know why you want to avoid it.
