aristocratic3d Posted October 5, 2014 Share Posted October 5, 2014 HI, I was wondering if I should buy a desktop or two laptop of the same processor. i7 3770? Price will be the same here. I am planning to use as render node for 3ds max vray. Thanks in advance. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted October 5, 2014 Share Posted October 5, 2014 My gut reaction would be to get the desktop. Heat is always an issue in laptops and rendering pushes a lot of temperature. Link to comment Share on other sites More sharing options...
Dimitris Tolios Posted October 5, 2014 Share Posted October 5, 2014 CPUs come in different versions for desktop & mobile use. Those designed for the latter are usually parts with far less consumption, as mobile devices usually try to maximize battery life. There is one strategy that guarantees that, and that of course is running the CPU @ lower clocks = laptops with "the same" CPU are usually slower. Sometimes notably slower, as we are talking parts with 50-75% less consumption. Performance comes from consumption - much like with cars & IC engines. Unless ofc you believe in magic. Yes, there are exceptions to the above, with certain laptop chassis using desktop parts. Those are big & heavy "portable" desktops more than thin laptops ofcourse, and usually are coming with high performance GPUs & decent screen panels, along with a pricetag to match...I would assume 3+ times the cost for such a laptop vs. building a stripped down desktop render node. Link to comment Share on other sites More sharing options...
