Randy liddil Posted December 12, 2014 Share Posted December 12, 2014 Does anyone know the best way to take a Sketchup file and bring it into Revit? Is the file able to be edited once in Revit? Is it a matter of exporting from Sketchup as a .DWG or is there a better way? Thanks for any help! Working in Sketchup Pro and Revit 2014 Link to comment Share on other sites More sharing options...
chrishuntsman Posted December 12, 2014 Share Posted December 12, 2014 The best way is to import your .skp file into a conceptual mass (it will an import option only inside the conceptual mass family). Once you have the .skp file imported into the conceptual mass, you can then import or load that family into your project. It will be a mass inside the Revit project so you will need to create walls/roofs/curtain walls/and floors through the massing options. Link to comment Share on other sites More sharing options...
