vray 2 sided material begginer
jonathan Evans
I have placed vray 2 sided material . i read that it has translucent properties.This based upon the viewer and the camera angle. i have applied the material currently it not showing the following properties. I am trying to locate why this has occurred.
thank you
see attachment of a dummy scene
2 side material need some finesse to work with. it is recommended to use single plane mesh and a strong light behind.
By the sample that you are showing, only with an environment light with a solid object it won't show the effect.
It is like look a window trough curtains at night, the interior light is stronger than the exterior light, so we won't see outside.
Put a plane light or point light, behind your mesh or inside, then you'll see the effect. Think like a lamp shade.
