4 GB GTX 980M or 8 GB GTX 880M?
Guest razackm
Guest razackm
Hi people,
I'm planning to buy a laptop for 3ds max, vray renderings, as i travel a lot. i'm confused to get the right configuration. My budget is under $3000, which narrowed down to two models.
ASUS ROG G751-JY and MSI GT72 2QE DOMINATOR PRO:confused::confused:
ASUS with 24 GB ram, 4 GB GTX 980M and MSI with 32 GB ram, 8 GB 880M.
which one should i go?
which one will be more stability?
any other laptop suggestions also would be great.
Kindly suggest..
Thank you. :rolleyes:
This is the "gpu rendering engines" forum area, but you say that you use vray for rendering. Do you mean vray RT gpu? If yes, go for the more vram, i.e. the 880m 8gb laptop. If you use the classic vray, choose primarily with cpu criteria. By the way, check this beauty out:
http://www.amazon.com/MSI-18-4-Inch-GT80-TITAN-SLI-263/dp/B00YPAVIX4/ref=sr_1_1?s=pc&ie=UTF8&qid=1440249174&sr=1-1&keywords=Laptop&refinements=p_n_feature_seven_browse-bin%3A3012497011%2Cp_n_feature_four_browse-bin%3A2289792011%2Cp_n_feature_three_browse-bin%3A9647486011%2Cp_n_feature_five_browse-bin%3A7817225011
