chaitanyajadhav1 Posted September 2, 2015 Share Posted September 2, 2015 Hi everyone, i am working on one interior project just for my portfolio and end up with two problems. 1. Light leaks 2. Noise i'm not sure the terms used here are correct for those issues and therefore i have attached an image for that. Please guide me through this. Thank you. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted September 3, 2015 Share Posted September 3, 2015 I think that you should be more clear about what you are doing, and that you should fill your portfolio with your own work. This image is a copy of work that I did last year for Neoscape: http://neoscape.com/wp-content/uploads/2014/07/448Beacon_Living_RFW.jpg Your portfolio is for showcasing your abilities. Copying another artists image is eliminating more than half the battle. Use this image to learn from and experiment with, but don't put it in your portfolio. That said, your noise is either a light subdiv issue or more likely a material subdiv issue. The light leaks are most likely due to either low Irradiace settings o, again, more likely, geometry that is either one sided or doesn't intersect with the walls. Link to comment Share on other sites More sharing options...
chaitanyajadhav1 Posted September 3, 2015 Author Share Posted September 3, 2015 Thank you Corey Beaulieu for your reference image and advise too. I'm using this image just to reach that level of lighting just for study purpose. Thanks for solution to my problems. Link to comment Share on other sites More sharing options...
