Noise and Light leaks for interior scene
chaitanyajadhav1
I think that you should be more clear about what you are doing, and that you should fill your portfolio with your own work. This image is a copy of work that I did last year for Neoscape:
http://neoscape.com/wp-content/uploads/2014/07/448Beacon_Living_RFW.jpg
Your portfolio is for showcasing your abilities. Copying another artists image is eliminating more than half the battle. Use this image to learn from and experiment with, but don't put it in your portfolio.
That said, your noise is either a light subdiv issue or more likely a material subdiv issue. The light leaks are most likely due to either low Irradiace settings o, again, more likely, geometry that is either one sided or doesn't intersect with the walls.
