tuantu Posted April 12, 2016 Share Posted April 12, 2016 Hello everyone, I have one problem with Vray 3.2 for 3dsMax. I can't use Vray Light Lister because when I click that button, nothing was happened ! I tried to make chance by set the keyboard shortcut for Vray Light Lister but it has the same result. Thank you if someone know how to help me ! Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted April 12, 2016 Share Posted April 12, 2016 Try to install V Ray again under administrator mode. Link to comment Share on other sites More sharing options...
tuantu Posted April 13, 2016 Author Share Posted April 13, 2016 Thanks Francisco Penaloza, I've installed again but it still doesnt work ! I tried to use "Light Lister" but there is no light ?! Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted April 13, 2016 Share Posted April 13, 2016 Max 'Light Lister' doesn't show Vray lights. Only 'Vray Light Lister' does. Link to comment Share on other sites More sharing options...
tuantu Posted April 13, 2016 Author Share Posted April 13, 2016 Yah, thank you Corey, but can you help me fix my problem ? I reinstalled many times but it still didnt worked. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted April 13, 2016 Share Posted April 13, 2016 Any chance it's just way off the screen? Try a script to reset all Max Window placements to 0,0: http://www.scriptspot.com/3ds-max/scripts/reset-3ds-max-windows Link to comment Share on other sites More sharing options...
tuantu Posted April 14, 2016 Author Share Posted April 14, 2016 OK, thank you Corey, i think it will help me Link to comment Share on other sites More sharing options...
tuantu Posted April 14, 2016 Author Share Posted April 14, 2016 Any chance it's just way off the screen? Try a script to reset all Max Window placements to 0,0: http://www.scriptspot.com/3ds-max/scripts/reset-3ds-max-windows I tried, but it doesn't work Link to comment Share on other sites More sharing options...
tommyg83 Posted March 17, 2017 Share Posted March 17, 2017 I tried, but it doesn't work Hey, did you have any luck fixing this? i've got the same issue.. tried reinstall of vray, even the alt+spacebar>minimize trick but it just shows up as an unsizable dialogue box, when i restore it it just disappears again... Link to comment Share on other sites More sharing options...
