matthewbrewer Posted June 8, 2016 Share Posted June 8, 2016 Hi can anyone help, I'm using DR in vray on 3ds Max 2014, I have two render nodes attached to my computer so I have around 20 buckets rendering at once. The issue I'm having is that one of the nodes is giving me strange results and the buckets it's rendered are different to everything else in the scene. I think the render node must be missing either a path or a plugin, but I can't seem to find anything missing. I am also working in linear workflow. Has anyone else had this issue and would you know how to correct it. (I've attached a jpeg to show you the problem) Thank you Matt Link to comment Share on other sites More sharing options...
Shaun Hamm Posted June 9, 2016 Share Posted June 9, 2016 make sure you have "transfer missing assets" checked in your distributed rendering settings Link to comment Share on other sites More sharing options...
matthewbrewer Posted June 10, 2016 Author Share Posted June 10, 2016 Thanks for the help, that fixes it when I use DR on my machine but when I send it off to the render farm, I still get the same issue. Thanks Link to comment Share on other sites More sharing options...
Shaun Hamm Posted June 10, 2016 Share Posted June 10, 2016 ah, i see. You have DR on and sending to Backburner. I had a similar problem but because i forgot to turn off DR before sending to backburner. I always turn DR off when i'm sending to Backburner because of issues like your having. Maybe someone else has figured out how to get them to play nicely together. Link to comment Share on other sites More sharing options...
Adrian Denne Posted June 10, 2016 Share Posted June 10, 2016 are all your textures able to be accessed by the renderfarm? Link to comment Share on other sites More sharing options...
matthewbrewer Posted June 14, 2016 Author Share Posted June 14, 2016 Yes, all the materials are on the server. I'm only finding one of the render nodes is doing it, the other one is fine. There both setup the same so I'm very confused. Thanks anyway guys, Link to comment Share on other sites More sharing options...
Tommy L Posted June 14, 2016 Share Posted June 14, 2016 Are all your VRay's the same version? Other than that, yes, its most likely a missing asset, probably a texture or a light file. Link to comment Share on other sites More sharing options...
jfgiroux Posted June 14, 2016 Share Posted June 14, 2016 (edited) Hi, I have had that same problem in the past mainly in max 2014 because they introduced the no gamma thing, the only way i fixed it is by using the Vray bitmap to VrayHDRI converter ( https://docs.chaosgroup.com/display/VRAY3MAX/V-Ray+Bitmap+Texture+|+VRayHDRI ) see bottom of the page. that works for me everytime Edited June 15, 2016 by jfgiroux Link to comment Share on other sites More sharing options...
larryhil Posted June 15, 2016 Share Posted June 15, 2016 Hello! I am also getting same issue. Link to comment Share on other sites More sharing options...
matthewbrewer Posted June 17, 2016 Author Share Posted June 17, 2016 Thanks, I'll try this out and see how it goes. Would you tick the 'Convert bitmap to EXR' option?? Link to comment Share on other sites More sharing options...
jasminepeterson Posted June 20, 2016 Share Posted June 20, 2016 There is no doubt that you would get better render times overall and more reliability with animations by using Backburner instead of DBR. DBR is great for stills, but animation, I don't really see the point. The simple fact that if a node dies during an animation your "master" machine running max will most likely crash as well would be enough to keep me from DBR on animations. In addition DBR does have to wait to finalize a frame until all buckets have rendered, with more than one or two nodes you WILL see a delay due to this phonmenon whereas with a traditional render farm each node will run at 100% and will not need to wait for anything. If you farm isn't all same - same in CPU and RAM this delay can become painfully obvious. With FG turned on you get to wait trice! Link to comment Share on other sites More sharing options...
