stayinwonderland Posted June 23, 2016 Share Posted June 23, 2016 So they took away the ability to change the output gamma in max 2015. Just using Vray which is set to 2.2, looks fine in the VFB but when I save it's really bright. What's the workflow I should be using? Link to comment Share on other sites More sharing options...
stayinwonderland Posted June 24, 2016 Author Share Posted June 24, 2016 (edited) please help, desperate. The CurrentDefaults.ini doesn't do anything when changed to 1.0 and saved. Edited June 24, 2016 by stayinwonderland Link to comment Share on other sites More sharing options...
James Vella Posted June 24, 2016 Share Posted June 24, 2016 this will work perfectly for this; http://jamesvella.blogspot.com.au/p/tutorial.html Link to comment Share on other sites More sharing options...
stayinwonderland Posted June 24, 2016 Author Share Posted June 24, 2016 thanks, will have a read of that. such a shame they got rid of this. I had a mess around which resulted in more or less the right 'kind' of gamma, but the result of the whole scene had a subtle change in light quality. Not good. Link to comment Share on other sites More sharing options...
Josef Wienerroither Posted June 24, 2016 Share Posted June 24, 2016 i think entering "fileOutGamma=1.0" in the maxscript listener before saving should work Link to comment Share on other sites More sharing options...
stayinwonderland Posted June 24, 2016 Author Share Posted June 24, 2016 yeah I did see that elsewhere, worked like a charm! Link to comment Share on other sites More sharing options...
