janisaufmanis Posted July 18, 2016 Share Posted July 18, 2016 Hi all, I am looking for some help - the goal is to make a realistic rendering ( of course). It's all good so far with materials and model. The issue is the environment reflecting on the building - we are not modeling the environment, but since we propose large glazed screen, the buildings from across the street have to be reflected. Even more - this is a historical city and that's a project on an intersection of 5 streets ( so there's a lot of different reflections from each angle) Can you please help and point out some smart tricks, or maybe lead me to other posts regarding similar problem? This is not super-urgent, so I'm also ready to invest some time for a better result. Thanks in advance, Janis Link to comment Share on other sites More sharing options...
Devin Johnston Posted July 18, 2016 Share Posted July 18, 2016 If you use Street View grabber you can generate a 360 panorama from any point in Google street view, this is the easiest way to create the reflections you want. http://jamiecardoso-mentalray.blogspot.com/2015/01/google-maps-to-streetview-grabber.html Link to comment Share on other sites More sharing options...
janisaufmanis Posted July 18, 2016 Author Share Posted July 18, 2016 Devin Johnston, This is a treasure! Haven't gone through all of the procedure yet, but so far I understand all of it and just could not wait to give big up! Thanks. Might pop up here again with some questions regarding this, but that was good Link to comment Share on other sites More sharing options...
janisaufmanis Posted July 21, 2016 Author Share Posted July 21, 2016 Devin, Sounds like you're experienced with this kind of thing. I am wondering what might not be working. I have the image, the small software was working perfectly fine. I will explain my process step by step ( shortly) and I would really appreciate if I could have some explanation of what I'm doing wrong. 1. Render setup/Vray/Environment Rollout. Here I simply choose my bitmap image for reflection/refraction slot ( and change nothing more) I have a feeling that something is wrong here, however I have the exact same settings as in the link you gave 2.Drag and drop this bitmap to material editor as an instance. 3.Drag and drop the instance to Environment rollout 4.Here the fun part begins- I select the viewport and press Alt+B. Viewport background options then open. They look a bit different from what I saw in the given link. Anyways, this has to do with the viewport, not with rendering, so let's not pay too much attention to this. 5.Suppose, I have adjusted my spherical bitmap, checked the environ option in the material editor and set up my materials. I am using simple dome light with no texture. And I hit render The result is without any reflection at all. Do you have any ideas? I went through all the process 3 times and double checked everything I imagined could be wrong. The mistake must be very silly and obvious, but there is no way I can work my way around it myself. Looking forward for any advices Janis Link to comment Share on other sites More sharing options...
