Ramon Folguera Posted September 15, 2016 Share Posted September 15, 2016 Hi everyone, I have this problem, which I am not sure if it can be fixed or it is just like that. The thing is that when I render the bump of the bricks words on one face of the facade of the building but not on the other one. See attached please, Thanks for the help Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted September 15, 2016 Share Posted September 15, 2016 You need to adjust the blurry values in your bitmap. you can set it up to 0.1 or 0.01. You could increase the effect using a mix of Normal maps and regular bump map too. Other than that, maybe your bitmap image may is low quality. Link to comment Share on other sites More sharing options...
Ramon Folguera Posted September 15, 2016 Author Share Posted September 15, 2016 You need to adjust the blurry values in your bitmap. you can set it up to 0.1 or 0.01. You could increase the effect using a mix of Normal maps and regular bump map too. Other than that, maybe your bitmap image may is low quality. Thanks Francisco Link to comment Share on other sites More sharing options...
