brinkadelic Posted December 4, 2004 Share Posted December 4, 2004 Anyone know how I can export a 2-D hidden line rendering of a view from a 3dS MAX 6 or VIZ model that I can edit it in AutoCAD? I am looking for a feature that I used to use in Microstation, "export hidden line" where I could capture a view of my 3d model (whether a sectional view, a plan view, a perspective, or an axonometric view) and edit it as a flattened 2D image with hidden lines, etc. Basically, I want to take a bunch of sections and axonometric views from my 3D model in 3Ds MAX (complete with hidden lines and objects in the distance), and edit them in AutoCAD. I know how to cut sections using the section object, but is there a way to actually export a view to a 2d (flattened) autocad image that I can work in Autocad? This way I can apply a slice modifier to my whole model and import a hidden-line drawing of that section view into AutoCAD... I've searched the web about this and asked a number of people, and I know that there was a plug-in called Vecta3D that came on a CD with VIZ 4 that would allow you to produce hidden line renders... But I'm not sure whether this means a hidden line type raster image, or a hidden line drawing that is a flattened 2D vector file of a 3D view (which I can edit in AUTOCAD). Any help would greatly appreciated! Link to comment Share on other sites More sharing options...
MrCAD Posted December 4, 2004 Share Posted December 4, 2004 plz check out this article..prolly it should help http://www.peachpit.com/articles/article.asp?p=169506&seqNum=30 meher http://www.drapefx.com http://www.mr-cad.com Link to comment Share on other sites More sharing options...
Videha Posted December 5, 2004 Share Posted December 5, 2004 ADT has a comand wich does yust that i think its "Hidden Line Projection" and works just fine. Link to comment Share on other sites More sharing options...
lebbeus Posted December 5, 2004 Share Posted December 5, 2004 here's a convoluted method: render out a line drawing from MAX/VIZ (using finalToon or some such thing) making sure that you are outputting a vector file (.ai or .eps or even .fla) --open that vector file in Illustrator 10 or above --save as an autocad dwg from Illustrator --open new .dwg in autocad and edit away is there an easier way?? Probably… maybe you could save your MAX/VIZ file as a .dwg or .3ds and open/import that file into auocad, then trace what you need and use flatten.lsp(search for it, it's free) to get the "2D" drawing Link to comment Share on other sites More sharing options...
