stayinwonderland Posted January 31, 2017 Share Posted January 31, 2017 I used to get around the new gamma output thing using: fileOutGamma=1.0 but it doesn't work any more for some reason. I paste it into the MaxScript window and my output images are still dark. I've been away from using max for a while so I might be missing something obvious. Max 2015 and Vray 3.3 Link to comment Share on other sites More sharing options...
James Vella Posted February 1, 2017 Share Posted February 1, 2017 i dont use vray anymore but I wrote a tutorial on this you can find here; http://jamesvella.blogspot.com.au/p/tutorial.html Link to comment Share on other sites More sharing options...
stayinwonderland Posted February 1, 2017 Author Share Posted February 1, 2017 yeah thanks, I had stumbled across that. Been in a hurry so didn't want to get into anything too deep, but what I did take away from that was to save as EXR. Did that and then went from 32 bit to 8 bit in photoshop. Link to comment Share on other sites More sharing options...
James Vella Posted February 1, 2017 Share Posted February 1, 2017 Good to know it helped. Let me know if you need anything clarified Link to comment Share on other sites More sharing options...
Josef Wienerroither Posted February 2, 2017 Share Posted February 2, 2017 As i understand, the fileout gamma will only be applied on a 8bit/channel image output Which format/bitdepth did you save to when the fileoutgamma=1 wasn't applied ? Link to comment Share on other sites More sharing options...
