Vray Proxy not rendering properly... Please help
jaychoi
you didnt save it right or you didnt connect your proxy file with proxy in scene. First select whole three and then go to vray export. Then select export all selected objects in single file. Then chose automaticly create proxies and put number of faces in preview. Check also box with multi material. Chose destination folder (so you can track it easy) and near File: put the name of proxy. If you have already created proxy pick bounding box and in modify tab file browse and find where did you save your proxy file.
