ipdesigner Posted December 7, 2004 Share Posted December 7, 2004 *i have this scanner HP model Scanjet 3500c (for pro, i guess), purchased awhile ago..first image attached is a sample output it gets, setting is resolution (ppi)=150, output type=millions of colors (24 bit). A yellow 'lines/stripes'. appears! most of the pictures comes out with the same results, even I increased the resolution, still the same. and takes a bigger file size! As sample, one image: resolution=150, 1197x1012x24b jpg = 1.62MB size! second image from HP Officejet G Series (3-in-1, printer-scanner-fax machine) from other PC, not mine....gets a better quality!! with the same image size, but not sure about the resolution.. *Whats the problem on my scanner? Does the resolution plays the role? Plsss help!. Link to comment Share on other sites More sharing options...
Wendelld Posted December 8, 2004 Share Posted December 8, 2004 If you've scanned it from a magazine, use the descreen function of your scanner to achive better result. Link to comment Share on other sites More sharing options...
ipdesigner Posted December 8, 2004 Author Share Posted December 8, 2004 Wendelld said: If you've scanned it from a magazine, use the descreen function of your scanner to achive better result. *"descreen function", cant find this in my scanner... *and mags and books take the same results, i think its not about the article type.. *btw, thnx! Link to comment Share on other sites More sharing options...
