steevenberube Posted May 8, 2017 Share Posted May 8, 2017 Hi guys, been having issue with this for a long time. Why is the light cache more saturated than the final image ? I use Vray Light sphere. I hate this because I have to wait until the light cache is finish to get a good idea of my image and if I dont, i got the lighting all wrong. See images here: https://ibb.co/bKc7Y5 https://ibb.co/kn6O6Q here are my settings: Reinard Gamma: 2,2 Multiplier 1,0 Burn 0,5 clamp, sub-p and affect B. all checked GI ON Irradiance Map Multi. 1,0 Light cache Multi. 1,0 Sat 1,0 Contrast 1,0 Contrast base 0,5 Ext. light comes from Vray sun with Default vray sky in the environment slot Anything else you need? Thx Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted May 10, 2017 Share Posted May 10, 2017 err. don't use Light cache.. or reduce the samples so it render quickly. Maybe your computer is too slow, I really don't see a major problem with this. Light cache is an approximation of GI lighting, it won't have the 'final' color because it is an approximation. Link to comment Share on other sites More sharing options...
Tom Sproule Posted May 13, 2017 Share Posted May 13, 2017 Because that's the way it's supposed to work. Light cache is calculating the light along a certain path and it gives a good idea of the final lighting, but it's only the secondary engine. The primary engine you're using is Irradiance map, and that calculates the lighting very differently. Your final lighting will be a combination of the two. If you think of lighting being a mix of the hard light coming from the main light sources (which would have the colour of the incandescent bulbs, or whichever type of light you put in) and all of the other bounces of light through the room, which would obviously take on some of the colour of the items the light is boucing off and normally has more white in it. So you wont get the final light details from light cache, you have to have both primary and secondary engine information to see what the final lighting will look like. Link to comment Share on other sites More sharing options...
