cedricmasella Posted August 14, 2017 Share Posted August 14, 2017 Good day I need some advice please. I am planning to get me a Dell PowerEdge R810 2nd hand and I want to use it as a render PC for 3d Max and Vray. There is only on board Graphic card. I work on one pc and would render on the Dell server. Would this work and can you render on the server knowing that the Graphic card is a very low spec? See link below. https://www.dell.com/downloads/global/products/pedge/pedge_r810_specsheet_en.pdf Kind regards Cedric Link to comment Share on other sites More sharing options...
jamesgallagher Posted August 14, 2017 Share Posted August 14, 2017 As long as you're doing CPU rendering and not GPU rendering is shouldn't make a difference. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted August 15, 2017 Share Posted August 15, 2017 Yes, James is correct, if all that you do is CPU rendering, you should be fine with any video card. Having said that, unless you are getting that rack server for a very, very good deal. I would recommend you to take a look any builded AMD Ryze or Threadriper machine, you will get way more rendering power for a fraction of the cost of that DELL Rack. That machine has too many features that you will never use. Link to comment Share on other sites More sharing options...
Josef Wienerroither Posted August 15, 2017 Share Posted August 15, 2017 If you get those generation of Dell servers from ebay, you really can make a good deal eg. for $500 a 20/40 core machine ( 2 Xeons equipped , from a total of 4 sockets available... ) http://www.ebay.com/itm/Dell-Poweredge-R810-2x-Xeon-E7-4870-2-4ghz-10-Core-64gb-3x-146gb-H700-2xPSU-/232313959254 ONE of those Xeons still costs over $4,5k alone here: https://geizhals.eu/intel-xeon-e7-4870-bx80615e74870-a615501.html CPU clock is a bit limited, but maybe you can find a higher clocked variant anywhere Link to comment Share on other sites More sharing options...
georgechianese Posted February 1, 2018 Share Posted February 1, 2018 I bought a poweredge r810. Have win 7 loaded on it. Have not been able to get max to run on it. Get msg, An error has occurred and the app will now close. Changed graphics to nitrous software with no luck.Did you get this to work? Link to comment Share on other sites More sharing options...
