anandram1 Posted October 17, 2017 Share Posted October 17, 2017 Hi im rendering a scene with the cam inside the car.. car is moving on the road.. the problem is the video sequence is flickering. Im using Irradiance Map and Light cache to render sequence.. Also i m storing Cache for every frame. What will be the correct render settings to render this kind of situation. Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted October 17, 2017 Share Posted October 17, 2017 Use brute force for first bounce and light cache for a second, you can pre-render light cache or render every frame. Link to comment Share on other sites More sharing options...
Corey Beaulieu Posted October 17, 2017 Share Posted October 17, 2017 Or, depending on your action, render a still of the interior of the car and then render Irradiace map of the of the exterior using Camera Path. Then use a compositor to put the exterior frames behind the interior. I would think you want this anyway so that you can motion blur the background. Link to comment Share on other sites More sharing options...
anandram1 Posted October 17, 2017 Author Share Posted October 17, 2017 Or, depending on your action, render a still of the interior of the car and then render Irradiace map of the of the exterior using Camera Path. Then use a compositor to put the exterior frames behind the interior. I would think you want this anyway so that you can motion blur the background. Hi Thanks, the steering wheels is animated... Link to comment Share on other sites More sharing options...
John Dollus Posted October 18, 2017 Share Posted October 18, 2017 so render the plate without the steering wheel and comp that in as a separate pass. Rendering a static dashboard in the animation pass is a massive waste given it likely takes up more than 50% of the screen Link to comment Share on other sites More sharing options...
