chrisclocher Posted December 13, 2004 Share Posted December 13, 2004 I have to make a parking lot in an irregular sloped area next to a building. I know how to create the sloped landscape and paved area, but I dont know how to create the curbing along the perimeter of the parking lot, can anyone give me some input? Link to comment Share on other sites More sharing options...
cullen Posted December 13, 2004 Share Posted December 13, 2004 there's a couple old threads that talk about this if I remember, but you can use shapemerge then extrude the new faces or there is a plugin called glue. You can get it here: http://www.itoosoft.com/english/freeplugins.html Hope that helps... crw Link to comment Share on other sites More sharing options...
chrisclocher Posted December 13, 2004 Author Share Posted December 13, 2004 Wow, that glue program looks great, thanks Link to comment Share on other sites More sharing options...
Diver Posted December 13, 2004 Share Posted December 13, 2004 MAN OH MAN... I worked for years solving this one, but here is the secret. Form your terrain. extrude your curbs... gutters... streets.. sidewalks or whatever has to be conformed to the slope. Be sure to extrude the object further than the difference between the lowest and highest elevations of the terrain. Create a copy of your terrain as you will need it! Boolean the curb and terrain using the "INTERSECTION" operand. this should leave you with a curb that follows your terrain.. just edit mesh and extrude the face 6" for the height of the curb. This works for gutter.. road, sidewalks, plazas... and on and on. IT WORKS GREAT, let me know how it goes. GOOD LUCK Link to comment Share on other sites More sharing options...
ShaunDon Posted December 13, 2004 Share Posted December 13, 2004 To model the curbs, though, your best bet is to use a plugin like Glue to conform a path spline to the surface, then create the curb object with a loft. Otherwise if you don't use the loft to control UVW mapping and tiling, the materials you apply will never look right when your curb bends or takes off at non-right angles to your UVW gizmo. ShaunDon Link to comment Share on other sites More sharing options...
