gianzanare Posted October 31, 2017 Share Posted October 31, 2017 Hello, is there any function of placing an HDRI Image as an instance to the environment menu in vray, while also using a vray dome light with the same HDRI map? And apart from being used to view the environment in the background? Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted October 31, 2017 Share Posted October 31, 2017 Create a vrayhdri material, load your HDRI into it, drag it into the slots of both the environment and the vray dome light. Whatever adjustments you do to the vray hdri material will apply to both instances. Link to comment Share on other sites More sharing options...
ahmeds Posted November 1, 2017 Share Posted November 1, 2017 From what I've heard from various tutorials, the reason you put the HDRI in the environment slot is for when you have Vray plane lights in Portal mode, it will take its intensity from the environment map not from the dome light. Link to comment Share on other sites More sharing options...
