mike_sul Posted December 14, 2004 Share Posted December 14, 2004 pls check this attached blow up of a vray 1.45.70 rendering .. final render resolution --------------------- 3600 x 4500 pixels settings -------- primary bounce = 1.35 -- irradiance secondary bounce = 1.0 -- light map irradiance map preset = high lightmap subdiv = 1000 sample size = scale = screen lighting ------- 1 direct light value = .4 with vray shadow vray skylight value = .55 color mapping ------------- linear multiply dark 1, bright 1 1) how do i brighten the internal illumination level .. 2) i see some light leaks like the one pointed out in (2). how can i correct them . I am on a deadline project pls advise. thanks, with regards .. mike sullivan Link to comment Share on other sites More sharing options...
MrCAD Posted December 14, 2004 Share Posted December 14, 2004 lower your secondary bounce value I guess and it should be fine meher http://www.drapefx.com http://www.mr-cad.com Link to comment Share on other sites More sharing options...
mike_sul Posted December 14, 2004 Author Share Posted December 14, 2004 MrCAD said: lower your secondary bounce value I guess and it should be fine meher http://www.drapefx.com http://www.mr-cad.com But wont that reduce the internal illumination futhur down ... as shown in (1) in the image Link to comment Share on other sites More sharing options...
MrCAD Posted December 14, 2004 Share Posted December 14, 2004 yes..it will reduce for (1) too..what u can do is play with the specular color a bit for material (the yellow ochre colors specular) and see..well the other way u can reduce the effect by detaching those particular faces of the building as a new object and goto the render->renderer->system->object settings..->select that building side object name from the left panel ->reduce the value of "Receive GI" hope this helps meher http://www.drapefx.com http://www.mr-cad.com Link to comment Share on other sites More sharing options...
