chandradeepsingh Posted December 11, 2017 Share Posted December 11, 2017 Good evening to all, I am a 3d designer .. i usually do lots of rendering in 3ds max-Vray_Corona for product designing, architectural designing. Just 2-3 months before i purchased a new assembled pc for my work... My Desktop configuration... Gigabyte GA- X99P-SLI Motherboard Intel Core i7-6800K Processor Leadtek Nvidia Quadro K1200D 4GB Gskill 2400mhz ddr5 8gb 2 slots 16gb ram SSD Harddisk 240 GB OS Windows 10 64 bit 3ds max 2014 vray 3.30.05 Corona 1.6.1 Issues am facing is when i put any scene on rendering ... CPU usage goes to 100% while ram is used only 40-45% and in manage gpu utilization my gpu utilization graph stays only upto 2-3% and while rendering whether its in vray or corona with 3ds max(Some times pc gets restart while rendering due to 100% cpu utilizing for long time)..if i play any movie side by side movie plays with jerks and freezing for 2-3 seconds in every minute & this constantly happen while rendering is going on... in 3ds max and only in 3ds max in veiwport at upper right & left corner near task bar green white dots are visible... I think my quadro is not utilizing and am facing theses freezing issues.. while rendering also my pc hangs a lot... Please help me if there is any option through which i can utilize my full quadro power or please tell me what is the issue if its now related with graphics... i have update all the software's regarding motherboard & graphics card no positive results..... if anyone can explain or help me... Plzzzz Link to comment Share on other sites More sharing options...
James Vella Posted December 15, 2017 Share Posted December 15, 2017 This all sounds correct. Rendering with Vray/Corona only uses the cpu - so it should be at 100% - which will make doing anything else almost impossible. Your GPU will be doing basically nothing while rendering. - If you render with Vray RT you can utililse the GPU - although you will have to check the manual as RT does not support all of Vrays features. - If you want to watch a movie you can sacrifice some of your rendering speed by lowering the affinity number in task manager (set the CPU amount for 3dsmax, and the rest for whatever you like, for a movie or browsing internet 1-2 CPU's should be plenty). If on Windows 10 go to Task Manager > Details > right click on 3dsmax.exe > Set Affinity - Ram usage is dictated by the size of your scene/assets - Your PC should not restart on its own during rendering unless its over heating Link to comment Share on other sites More sharing options...
