belemaogan Posted February 24, 2018 Share Posted February 24, 2018 Please i need help in generating a mesh, using loft tool in max2016. the shape generates to the vertical, instead of the horrizontal. Rotating the vertical to horrizontal doesnt give the desired shape. Both the path line and shape line are drawn in top view Link to comment Share on other sites More sharing options...
belemaogan Posted February 24, 2018 Author Share Posted February 24, 2018 urgent help needed please. I am stuck Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted February 24, 2018 Share Posted February 24, 2018 When using loft tool you have two options, get the path or get the shape I usually use get the shape, because the path is what I want to be followed. Now when you draw the shape in a top view what is looking up is the direction that it will extrude. So if you are drawing, for example, a rectangle with a pup up at the right side, when you use the loft tool that pops up will be on the left. This, of course, will vary if you draw the path to be followed from top to bottom or from bottom to top. In resume, yes loft tool is kind of weird, but if you understand how it works it becomes very useful. Depending on what you are looking for you could also use, sweep modifier or other Link to comment Share on other sites More sharing options...
igoldrategold Posted February 25, 2018 Share Posted February 25, 2018 When using loft tool you have two options, get the path or get the shape I usually use get the shape, because the path is what I want to be followed. Now when you draw the shape in a top view what is looking up is the direction that it will extrude. So if you are drawing, for example, a rectangle with a pup up at the right side, when you use the loft tool that pops up will be on the left. This, of course, will vary if you draw the path to be followed from top to bottom or from bottom to top. In resume, yes loft tool is kind of weird, but if you understand how it works it becomes very useful. Depending on what you are looking for you could also use, sweep modifier or other Thank you for the replies Link to comment Share on other sites More sharing options...
