jeanpaulelhachem Posted March 25, 2018 Share Posted March 25, 2018 Hello guys, I have a problem when rendering an interior scene animation. It is a little bit confusing. When I render a single frame the view seems to be fine, but once I run the animation a black pixels cloud appears in the frame. Does anyone know what can be the source of the problem?! Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted March 26, 2018 Share Posted March 26, 2018 Well, first it would be very useful to know what software you are using, and also what are your settings. Guessing that you are using some raytracer software, your problem could be, interpolation, this is a trick that most raytracers use to render faster, there are some workaround to this, if you still want to use that method, (instead of brute force) just Google your software name and animation workflow. for example. 3dMax VRay animation workflow. Just be sure any information you find it matches the same Software version of what you have, because software changes all the time, what used to work before it may not work now. Cheers. Link to comment Share on other sites More sharing options...
jeanpaulelhachem Posted March 26, 2018 Author Share Posted March 26, 2018 Hello Francisco, Thanks for replying. I am using 3dsmax and Vray 3.6 as my render engine. Find attached the Settings, and note that I tried to replace irradiance map with brute force as the primary engine and got the same result when rendering the animation. Link to comment Share on other sites More sharing options...
