3darchitect Posted August 29, 2018 Share Posted August 29, 2018 I'm working with a rather complicated site that has lots of ups/downs and retaining walls. I have contour lines from Civil but because there are so many retaining walls (and buildings acting as retaining walls) I'm not sure what the best way to go about modeling this in Sketchup. Right now my approach has been to clean up the contours as best as I can but I'm not even sure how to best create geometry out of them in Sketchup because of all the disconnected contours (due to retaining walls). Does anyone know of any good tutorials out there for how to address this? Link to comment Share on other sites More sharing options...
Jason Matthews Posted March 3, 2019 Share Posted March 3, 2019 I know this is really late, but you will have to manually assume the topo at the retaining walls. All topo should essentially stop and redirect at each wall or building. If you have access to Revit, this would be the best to use, IMO. Link to comment Share on other sites More sharing options...
