Mikeelee Posted September 6, 2018 Share Posted September 6, 2018 does anyone have a V-ray camera rig so I can animate a walkthrough? path animation is not working for me and I need to learn the curves editor but no time! Cheers Mike Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted September 7, 2018 Share Posted September 7, 2018 I may be overlooking something, but i do not think your question makes any sense. What do you imagine a camera rig would look like? Animations are just a camera and a target, keyframed. Either animated along splines, or if the movement is linear you do not need splines at all. All you have to do is add keyframes to the camera and the target, and right click the keyframe to select different modes of movement (the default is an easy "fade" from standstill to movement, but i guess most of the time you would just want the movement non-adjusted.) I highly doubt anyone would have a setup with an animated camera that is gonna match exactly the movements that you need in your project. Some light reading, its really not that hard: https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/3DSMax-Animation/files/GUID-99745DB9-C1A9-47B2-8481-91975FC3A399-htm.html https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/3DSMax/files/GUID-4C66C673-16A3-4235-BDB5-B8D973E06FB4-htm.html Good luck! Link to comment Share on other sites More sharing options...
James Vella Posted September 8, 2018 Share Posted September 8, 2018 this is a pretty good camera rig with a crane/jib script, used it on a few animation projects and its very easy to use http://www.scriptspot.com/3ds-max/scripts/camera-jibrig-creator Link to comment Share on other sites More sharing options...
