AdamRosauio Posted February 27, 2019 Share Posted February 27, 2019 I'm looking on advice for Lighting - 3D Floorplan Renderings. Im modelling in Sketchup and rendering with the Vray 3.6. The current attached example is lite with a Dome Light with the HDRI shown. Ive bumped up the intensity to about 40 with a Exposure Value of 14. I've tried a bunch of other lighting ideas, but just looking for other suggestion. Would love to get the effect of sun light though the windows, but that has been difficult too achieve with good results. Any suggestion how i can improve, or try? Thanks Link to comment Share on other sites More sharing options...
Nicolai Bongard Posted February 28, 2019 Share Posted February 28, 2019 Change your HDRI to one with a sun? Looks like the one you are using is indoors and with artificial lights only? Thus your geometry will be lit pretty much like the interior you see on your HDRI. If you are looking for free HDRI`s you could try the noemotion ones, they have a good selection of HDRI`s and you should get better results! If you want to keep the lighting and just insert additional lights from the windows, try to create a targeted light that is pointed through your window, make sure the size covers the opening and change the directional option from 0 to 1. Then you instance that light around for all the windows. That should result is "spotlights" that acts as the sun shining through your windows. Link to comment Share on other sites More sharing options...
AdamRosauio Posted February 28, 2019 Author Share Posted February 28, 2019 Thanks Nicolia, If I change to a sun HDRI then I get sun shadow, which I dont want. Is there away to avoid that? I've tried an overcast day one before and just bumpout the values, maybe i can try that again? Link to comment Share on other sites More sharing options...
John Dollus Posted February 28, 2019 Share Posted February 28, 2019 AdamRosauio said: Would love to get the effect of sun light though the windows AdamRosauio said: If I change to a sun HDRI then I get sun shadow, which I dont want. Is there away to avoid that? Confused - which do you want? Link to comment Share on other sites More sharing options...
AdamRosauio Posted February 28, 2019 Author Share Posted February 28, 2019 Short answer is both. Im trying to get similar lighting too these. https://3dplans.com/products/3d-floor-plans/ Link to comment Share on other sites More sharing options...
Francisco Penaloza Posted February 28, 2019 Share Posted February 28, 2019 put a box as ceiling/roof and make it invisible to camera, then you can use Sun/Sky combo if you like or any type of lighting. You'll need to place interior lights though just like a regular render. Link to comment Share on other sites More sharing options...
AdamRosauio Posted February 28, 2019 Author Share Posted February 28, 2019 (edited) fco3d said: put a box as ceiling/roof and make it invisible to camera, then you can use Sun/Sky combo if you like or any type of lighting. You'll need to place interior lights though just like a regular render. Ive though of that but couldnt figure it out, i can do in max, but not vray in sketchup. Im assuming that is within the vray setting to hide, or ingnore object from scene, view, camera. Ill look again. Found it, its under a material setting, Raytrace Properties, only in Secondary. Not sure that the "right" way todo it but its the effect. Edited March 1, 2019 by AdamRosauio Link to comment Share on other sites More sharing options...
