trhoads Posted December 22, 2004 Share Posted December 22, 2004 Hello all, I need to know the difference between DVD-RW and DVD+RW. I have figured out that they are not the same, and drives will only write to one or the other, but is there a difference between the two. The main use for now will be data storage and backup, but eventually I would like to get our portfolio and marketing info on DVD to give to prospective clients. So I would like to get the correct type for doing both. Any advice or wisdom that you folks might be able to share woudl be great. Thanks. Link to comment Share on other sites More sharing options...
Ray Posted December 22, 2004 Share Posted December 22, 2004 My drive writes to both. It's all about compatability with the piece of equipment that you will be reading with down the road. Very similar to the Betamax vs. VHS issue. Link to comment Share on other sites More sharing options...
Sawyer Posted December 22, 2004 Share Posted December 22, 2004 I believe + r is the more prevelent. Link to comment Share on other sites More sharing options...
Jeff Mottle Posted December 22, 2004 Share Posted December 22, 2004 My experience is that MANY architects/developers don't even have DVD drives in the office. This should help explain things a bit though: http://www.webopedia.com/DidYouKnow/Hardware_Software/2003/DVDFormatsExplained.asp Link to comment Share on other sites More sharing options...
trhoads Posted December 22, 2004 Author Share Posted December 22, 2004 Thanks everyone. Jeff, you are right, not many architects do. But we rely so much on our data backup, for drawings and renderings, that it was getting too cumbersome and time consuming the way I was doing it. When my computer alone needs 4 GB worth of backup space, on a media that is portable and easy to store, DVD was the only way for me to go. I ended up with a DVD+RW drive, and discs. So much easier than anyhting else that I have used to date. It worked great, and I would reccomend it. Link to comment Share on other sites More sharing options...
Bugga_Guy Posted December 23, 2004 Share Posted December 23, 2004 Dvd-rw and Dvd+rw is like Beta and VHS all over again. Link to comment Share on other sites More sharing options...
Ray Posted December 23, 2004 Share Posted December 23, 2004 Bugga_Guy said: Dvd-rw and Dvd+rw is like Beta and VHS all over again. D-oh! Wish I'd thought of that. Link to comment Share on other sites More sharing options...
Christopher Nichols Posted January 2, 2005 Share Posted January 2, 2005 Bugga_Guy said: Dvd-rw and Dvd+rw is like Beta and VHS all over again. Yes and no... There was actually a much better quality in Beta which is why it is still used by professionals today. The difference in quality between +r and -r does not really exist. It is mostly a matter of compatibility. These days any new DVD player will play +r or -R... but since -r came first, there are older player that will not play -r format. There are also very old players that will not play either. My burner will do both. I use -r for all video stuff that I do (to maximize my compatibility), and use +r for my data. For the only reason that my burner will burn +r at 8x and -r at 4x... so it is faster. Now DVD-HD and Blu-Ray... that is Beta vs. VHS. Blu-Ray is better BTW.... it has double the data Link to comment Share on other sites More sharing options...
jd0000 Posted January 3, 2005 Share Posted January 3, 2005 DVD+RW will be your best bet. But I did see a sony DVD+RW / DVD-RW 16x write speed for 100 bucks at bestbuy. That sounds like a pretty good deal. Link to comment Share on other sites More sharing options...
hockley91 Posted January 3, 2005 Share Posted January 3, 2005 Make sure you get the new dual layer DVD burners. They hold twice as much information and as the months go on the write/rewrite speed will get faster as well. Link to comment Share on other sites More sharing options...
Christopher Nichols Posted January 3, 2005 Share Posted January 3, 2005 The new dual layer DVDs hold about 8 gigs. From what I saw their media is pretty expensive... the new Blu-Ray format is around 25 gigs. Expect the players to come out in less then a year, that means burners and media will be out in soon after that. Link to comment Share on other sites More sharing options...
