Node goes into sleep mode during rendering
charlieinolas
Hi,
Maybe someone could give me a hint.
What setting is resposible for preventing my node (laptop) from going into sleep mode during rendering?
I use vray - laptop has vrayspawner launched, connected via lan cable to deskop computer. Laptop (node) has sleep mode function turned on (let's say to 1hour. )
In my case, after 1hour, without touching mouse, or keyboard, laptop will go into sleep mode no matter if the rendering is still on and vrayspawner uses almost 100% of the proccessor power.
I would like to leave sleep mode on and don't set it to 'never', as I ofter forget to turn my laptop off for the nighttime :)
thanks
This guy has a script which you send to deadline as a job, so when that job is activated it should shut down the pc for you.
https://www.punch.digital/auto-shutdown-pc-after-rendering-with-backburner/
looks like the link to the script is down you could either contact the guy directly or try another such as
http://www.scriptspot.com/3ds-max/scripts/autoshutdown
Edited by redvella
ah you are correct I see.
In my case I also use my laptop and have 2 power modes (on auto mode). 1. never sleep when power is connected 2. sleep after 10 mins on battery.
I also use windows scheduler to power it off if its been idle for an hour or set it to a timer if i know the render times. Not a fix but my workaround
