kippu Posted December 28, 2004 Share Posted December 28, 2004 I was doing some 3dwork in sketchup and i cannot export smooth curves from sketchup to 3dsmax.... Can someone give me some pointers on how to export smooth curves out of sketchup into max Thanks all Link to comment Share on other sites More sharing options...
mwhite Posted December 28, 2004 Share Posted December 28, 2004 You could post a question on the SU forum as there has been discussion over there on this issue. Or, do a search on the SU user forum for "weld" and "3ds" and "smooth" and there should be some comments on how to fix the problem. I've updated this reply - here is a link to the issue. http://www.sketchup.com/forum/read.php?f=4&i=39210&t=39210 Mike White Link to comment Share on other sites More sharing options...
Bugga_Guy Posted December 28, 2004 Share Posted December 28, 2004 I dunno if this works but, have you tried to increase the valve of the soften edge in sketch up? Erase Tool By holding down the Ctrl key while using the Eraser Tool, you can soften edges instead of erasing them. Context Menu By clicking on an edge, you bring up its context menu, from which you can soften and unsoften the edge. Soften/Smooth Command By first selecting multiple edges with the Select Tool, then right clicking on the selection set, you can choose Soften/Smooth Edges from the context menu. This launches the Soften/Smooth dialog box described below. Entity Info Dialog Box By right clicking on an edge and selecting Properties from the context menu, you can adjust the soften and smooth setting for that edge in its Entity Info Dialog Box. Window> Soften Edges Finally, you can soften and smooth edges by selecting the Soften Edges menu item from the Window menu. Link to comment Share on other sites More sharing options...
kippu Posted December 30, 2004 Author Share Posted December 30, 2004 thanks. i will investigate further Link to comment Share on other sites More sharing options...
RManns Posted December 31, 2004 Share Posted December 31, 2004 Export it as a DWG first, that way everything is pre-welded. That should solve your problem. Sketchup surfaces are independant from one another, so basically you just have a bunch of surfaces that are adjacent to each other and are not actually connected. By welding the points you'll be able to smooth it out. Link to comment Share on other sites More sharing options...
